10 bolt for 88 c-1500
Well tonite started to replace axle seal on a 88 chevy c-1500 with an open diff.Everything was good until the center pin bolt broke completely.Only the head and about 5-6 threads came out.Center pin is locked in.Can anybody tell me how to get the rest of the bolt out?I tried to coax it out with a small screwdriver and magnet.I have been told to drill it but I don't want to hurt the center pin or the threads that are still good in the carrier.Think that I can force the center pin out?Any help would be appreciated.
I have delt with this many times, I have a small pick set that sometimes I can get it out without much fuss. If that doesn't work your going to have to die grind the pin to let it slide by the bolt, small price to pay unless you get mad and just drive the pin out with a big hammer and a punch.
You might try grinding a slot in the broken piece with a Dremel so you can use a screwdriver on it. Also could try that on the other end.
I'm sure if you take the carrier out of the housing it will be easier to work on also.
