Complete gear and rebuild kit?
has anyone used the thunderracing deluxe gear install kit? is it worth the money? it comes with
Deluxe Kit: Includes pinion shims, carrier shims, crush sleeve, pinion seal, pinion nut, ring gear bolts, cover gasket, pinion & carrier bearings, PLUS wheel bearings and seals. MOTIVE Gears, in your choice of ratio...3.42, 3.73 or 4.10
Or, STRANGE Gears (2 or 3 series carrier) for $35 additional
RATECH Complete Gear Installation Kit
2 Quarts RED LINE Synthetic Gear Oil
1 Bottle GM Limited Slip Differential Additive
TA Performance Rear End Cover Girdle
TA Performance Stud Kit
All for $469.00 shipped
and what exactly is a rear end girdle?
Thanx
Thanx
Thanx
Thanx
A Brazilian butt lift?
Just kidding.
I just ordered that but the motive gears are on backorder and Thunder Racing told me it won't be shipped until Feb. 8th. I figured I it would be a good refreshment for a rear end that has 100,000+ miles on it.
