Magnaflow Catback
Old 01-22-2006, 10:20 PM
T/AFOSTERWS6's Avatar
Default Magnaflow Catback
Stupid Question But, Will This Catback Slip Over My Catted Tsp Y-pipe Or Will I Have To Adapt?,
I Cant Find Pic's Anywhere And My Car Is Not Accessable To Measure The Diameter Of The Pipe.
3" Y-pipe
Thanks Again For Your Responses, You Have Already Helped Alot
Old 01-22-2006, 11:17 PM
!LS1 11 Second Club
SouthFL.02.SS's Avatar
I can't give you a definite yes, but I would certainly think that it would.
Old 01-22-2006, 11:56 PM
BudH's Avatar
Almost every y-pipe steps down to a stock 2 3/4 outlet at the rear. The Magnaflow Catback (and almost every other catback I've seen) is designed to fit that 2 3/4 inch section.
Old 01-23-2006, 12:11 AM
01TAFlyer's Avatar
There is a good chance you will have to cut the i-pipe of the catback to fit the y-pipe. No big deal, just from my experience that the aftermarket orys and so forth extend further back than the stock location.
Old 01-23-2006, 04:37 PM
anyone else have this setup?
Old 01-24-2006, 06:27 AM
greatwhite99's Avatar
I have this exact setup. YOu may need to rent a exhaust pipe expander from autozone to open up the pipe a little bit to install the cat back. Otherwise it should fit like a glove.
Old 01-24-2006, 09:53 AM
TroubledWine3's Avatar
Yep, I had to cut slots in my catback to get it to mate to the TSP ORY, but then I put a bandclamp over it and no leaks since August.
