Gears & Axles - tighten up the e-brake cable???
soundengineer
01-24-2006, 10:06 PM
I just want to tighten up the e-brake cable...its always been where I have to really pull back hard on the e-brake to get it to hold...and I want it to grab sonoer..how do I adjust it??
SUX2BU
01-24-2006, 10:37 PM
If you've ever adjusted drum brakes its the same thing. just pull off your rear rotors and you'll see the E brake is just a small drum brake.
soundengineer
01-24-2006, 10:46 PM
cool...
I didnt know if it was a cable thing or a drum thing on teh ls1's
blkbird
01-24-2006, 10:52 PM
:bang: I also have the same problem and it is annoying the hell out of me!!!
TheBlurLS1
01-24-2006, 10:59 PM
The rear brakes on our cars have a drum INSIDE the disk. Pretty sweet huh? :D
If you remove the caliper, you will see a little knob in between the bottom of the e-brake shoes. When you pull the e-brake, the cable pulls on this little unit and forces the brake shoes apart. The adjustment knob sets a preload on them........ I think. LOL
Never actually done it, but i was looking at it about 2 days ago :jest:
That's all there is too it, just adjust that little wheel until you can just barely get the disc back on.
vBulletin® v3.7.4, Copyright ©2000-2013, Jelsoft Enterprises Ltd.
Search Engine Optimization by
vBSEO 3.5.2
