rear end noise
Old 02-01-2006, 10:26 PM
who281's Avatar
Default rear end noise
i have a 2000 camaro SS and its only got 28000 miles on it and is in GReat condition but lately the rear end has been making a loose rattling noise...like when ever i hit a bump or if i hit the left rear tire with my fist it rattles like sumthing is loose??? wats wrong???
Old 02-01-2006, 10:43 PM
MM98's Avatar
Had this same problem... Check your rear trailing arm bolts/nuts... Mine was a little loose on my driverside & was causing all kinds of noise.
Mike
Old 02-01-2006, 11:08 PM
bikemanx2's Avatar
i had a problem similar to this after I installed my sfc's. The lower control arm bolts came loose. Check those, they can make lots of noise.
