Zexel-Torsen Question
Old 02-02-2006, 09:23 AM
AWS-Z28's Avatar
Default Zexel-Torsen Question
I have a 99 LS1 Camaro M6 Zexel-Torsen rear end currently sitting in my garage. My question is when I rotate one axel the other axel turns in the OPPOSITE direction. Is this normal?? My 93 LT1 axels rotate in the same direction when I have it in the air.
I know that Zexel-Torsen are different than the rear end I have in my 93 because they use gears and not clutch paks, but should the axels rotate in the Opposite direction or is it broken???
Old 02-02-2006, 11:15 AM
12secSS's Avatar
Correct! That is how the torsen works.
Old 02-02-2006, 12:24 PM
AWS-Z28's Avatar
Thanks for the answer, I did alot of reading and thought it was correct, just wanted to make sure.
