stealth nitrous kit?
anybody running a kit that is easy to hide. I want a kit that won't be obvious, so it will look like a mostly stock motor. Anything will help thanks.
Look at Jegs or Summit and they have a bottle called "Sneaky Pete." Its really long and skinny so its easy-er to hide. Then just run the lines under the door jams and route it into te back or bottom of your induction system. Not perfect but not hard to do.
Originally Posted by Sgt. Spuds
Get the money maker from nitro daves...
but yeah, they can make you a direct port kit that is hidden UNDER the intake and you could find a tricky place (like in the dash) to hide the bottle.
IT will cost you about $800 give or take
