hooker header install help
Old 02-08-2006, 06:11 PM
408 z28's Avatar
Default hooker header install help
i've clearanced the k member more than enough to clear but for some reason they won't clear one of the head bolts any advice
thanks
Eric
Old 02-10-2006, 10:35 PM
WILWAXU's Avatar
it takes a little finesse.
Old 02-11-2006, 01:14 AM
That's what she said...
TheBlurLS1's Avatar
Unbolt the tranny mount and tweak it over a little bit. Use a prybar or somthing and the motor mounts should flex enough so that you can gain a little clearance clarance. Just make sure you dont put the squeeze on anything.
Keep playing with it and it'll go
Old 02-11-2006, 04:09 AM
MaxxMitchell's Avatar
A little wack with my palm got R done.
They were Jet Hots btw, had to take out the oil filter, and the thing above it, no idea what it was but it had 2 10mm bolts holding it on. K member was clearenced pretty well, and deburred. They look good now that they are in
Old 02-11-2006, 12:24 PM
WhiteRhino's Avatar
The thing above the filter is the oil divertor.You should of just removed the filter amd divertor along with the steering arm without clearancing the K-member.If I bought a set of headers and had to clearance anything I'd send them back!
Old 02-11-2006, 01:26 PM
J E T's Avatar
http://www.bowlingss.com/Mods/Instal...20Pictures.mht
