Should i swap out gears ?
Old 02-12-2006, 01:53 AM
5.7LoFuN's Avatar
Default Should i swap out gears ?
i currently have 2.73 rear and im going to replace all the bearings in the rear. Im getting ready to run a D1, so should i even bother to switch ratios while im at it, or should i stick with 2.73? If i make a change i was thinking of stepping up to 3.42 (the car is an A4)
Old 02-12-2006, 07:50 AM
EPP
EPP's Avatar
I'd go up to 3:73 gears, you will be surprised at the increase in acceleration. Since you have an automatic, the 10 bolt may survive for awhile. Bob
