TD's under the axle
TD's under the axle
My car is a daily driver and I need to put cats on it due to the exterior sound level. I'm also going to run my duals out the back under the axle. This may be a dumb question but when I have the pipes built to go under the axle would it be possible to put two hi-flow cats in those pipes?
I want to do this because then if I went to the track I could just unbolt those two pipes and run w/ no cats. Thanks ahead for the help guys
Tyler
Tyler
Yep you need the cats straight off the headers.
Also a good cat won't affect exhaust flow much or maybe at all, they may affect the exhaust pressure wave but on a street engine I don't think it's much to worry about.
Random Tech offer some nice CATS their 7000 series metal matrix ones outflow many mufflers and are good for ~550bhp if you run one per cylinder bank.
Magnaflow carsound CATS are also very good and probably will pose only a minor restriction (of that) on your setup.
