Spohn Ls1 Solid Motor Mounts..
Old 02-17-2006, 11:18 PM
OldBlue's Avatar
Default Spohn Ls1 Solid Motor Mounts..
I'm considering getting a set of these for my supercharged 02' camaro. And I was just curious about them, if anyone is running these or has any info I'd appreciate it.
Old 02-18-2006, 09:28 AM
OldBlue's Avatar
Someone is bound too be using these......
Old 02-18-2006, 10:43 AM
blue01ta's Avatar
I'm sure there are people on here running solids but it seems anymore most are running poly mounts. Just something else to keep in mind. The polys are only like $50 and a lot of people claim they are just as good. I will be getting some soon.
Old 02-18-2006, 10:46 AM
ashade98's Avatar
Poly mounts are great! Haven't tried solid, I'm sure they vibrate ALOT!
Old 02-18-2006, 10:47 AM
BLK02TA's Avatar
How hard is it to install motor mounts on these things?
Old 02-18-2006, 10:57 AM
ashade98's Avatar
My poly mounts took all day. Once you get them out, you have to drill out the rivets out of the clamshell, pull out the old mount, I painted the clamshell... reinstall the new poly mount.
I had to take out the pedistal that the mount is attached to also. There is only (4) bolts on the mount, I think (3) maybe (4) on the pedistal, and (1) that holds 'em together. You also have to remove your alternator.
Not sure about longtubes, I put in my mounts in before LT's.
It's a PITA.... Get some Mechanics gloves (save some skin)!
Good luck
Old 02-18-2006, 11:27 AM
SidewayzOZ's Avatar
Im using Spohn poly mounts and I love them. No noticed vibrations and it stopped my motor from moving all over the place with the cam.
Old 02-18-2006, 09:56 PM
OldBlue's Avatar
Thanks for the feed back fellas......
Old 02-21-2006, 03:05 PM
Zeus's Avatar
I have the Spohn solids as well and have no problems with them. Even before I did the cam I didn't notice any additional vibrations in the car (though I did them with my LT swap so the noise could be covering them up). I have a cam now and I still have no complaints. My car obviously is a little more animated now, but it has nothing to do with the mounts.
Overall I would recommend them though you also can't go bad with poly's.
Old 02-21-2006, 04:57 PM
4.6gt-2-ls1ta's Avatar
motor mounts aren't that hard and I didn't remove the altenator or my headers I just worked around them. It is time consuming, but not hard just stay calm and be patient. Darrin are you gonna be driving the car on the street or are you gonna keep it on the track? I didn't do the solid mounts, but if I didn't like a little shake with my car the polys would be pushing it for a DD car. You know what kinda car guy I am so take that as you will, but at the same time fugetaboutit put in the solid mounts. good luck with your decision
Michael
Old 02-21-2006, 05:55 PM
SUX2BU's Avatar
I daily drive solid motor mounts and LOVE it. The only down side is when you go to pull your tranny out.
Old 02-22-2006, 01:51 PM
SSpeedracer's Avatar
Just got some solid motor mounts in my convertible. Gone is the low frequency vibration from the engine lope (220 cam). Gone is the exhaust banging the body.
Feel and reaction to the drivetrain has improved as one would expect. Noise is up a little bit but hardly noticable. Not nearly as loud as when I was running without cats. I've got a little more medium frequency vibration/sound that is barely noticable when cruising.
The only negative is the feedback from the road. I used to be able to feel every little pebble or nuance on the road. Its hard to determine if the vibraiton from the seat/steering wheel is a pebble or the engine now.
Old 07-09-2010, 02:12 AM
BFarrier's Avatar
i just ordered spohn solid motor mounts should get them next week then longtubes then cam!!!!!!!!!!!!!!!!!!!!1
Old 07-09-2010, 02:21 AM
02sleeperz28's Avatar
I will be doing motor mounts this fall when I get my K-member installed.
Old 07-09-2010, 06:47 AM
FST SS's Avatar
love mine, rearview mirror vibrates a little but it did when I turned the stereo up too.
Old 07-09-2010, 02:45 PM
SS4Luck's Avatar
wow congrats on digging an old useles thread up
Old 06-28-2017, 11:15 PM
Wave's Avatar
Default Spohn solid motor mounts
i have the mounts already ........
What size bolts do i use to attach the mounts to the k-member
Old 06-28-2017, 11:23 PM
Received 3,025 Likes on 2,356 Posts
Don't the K-member instructions tell you? Or call Spohn. Might be quicker than waiting here for response to a 11 year old thread
Old 06-29-2017, 04:46 PM
sjsingle1's Avatar
I have the spohn non solid mounts and used the stock bolts to the K
Old 07-04-2017, 11:58 AM
Dan45's Avatar
Great mounts, takes some weight off the nose. I like them... better than poly ones
Quick Reply: Spohn Ls1 Solid Motor Mounts..
