rev limiter?
Old 02-20-2006, 12:06 PM
Black30thz's Avatar
Default rev limiter?
do MT have rev limiters? i thought that the rev limiter was for when there was something wrong with AT and it won't shift out. if there are rev limiters on MT where are they kicking in at? redline? thanks in advance.
Old 02-20-2006, 12:12 PM
DONAIMIAN's Avatar
I think the stock limiter is at 6250, but not sure, just know that its somwhere around there. The stock tach isnt the most acurate thing in the world, so dont take it too seriously. A shift light is a much better tool to go off of.
Old 02-20-2006, 12:36 PM
slow trap's Avatar
6250 sounds about right, but you will allready be on the limiter before that factory tach gets there.
Old 02-20-2006, 08:09 PM
Optimus_Prime's Avatar
Well the factory taks arent off, just very lazy for the first two gears they will probably be a little bit behind. But 6250 sounds right...if you wanna make sure then pop it in neutral and put the petal to the metal
