Got some specific questions about the Predator...
I'm looking for a tool that will let me tune my car for new gears and for a new cam. LS1-Edit would be preferable, but the cost is pretty prohibitive.
I was looking at the Predator, but I want to see if it has the functionality I want.
Can it:
-tune A/F ratio for both power enrichment mode and normal cruising mode?
-tune A/F ratio at specific points along the RPM curve?
-Adjust idle speeds, both normal and fast, in/out of gear?
I'm talking about WITHOUT custom DiabloSport tuning. If I'm gonna need that, I may as well just get LS1-Edit. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
Thanks
Mark
Can it:
Thanks
Mark
Re: Got some specific questions about the Predator...
For what you intend to modify LS1 Edit would be a much better solution. The Predator has it's place but it is not the best solution for tweaking and getting the most out of a combination in my opinion.
Tim
Tim
I don't think Predator does what you want. It allows you to add or subtract fuel or timing, (from their settings) but not at specific points. And it does not allow you to adjust the idle. Or at least if it does, I haven't been able to find it yet.
