Turning off AIR
Turning off AIR
I just installed headers and block off plates for AIR. i also removed the hoses, how do i actually turn off the pump it doesnt run at startups anymore in ls1edit?
Re: Turning off AIR
You could always unplug it and remove for a little extra weight reduction <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<img src="http://www3.sympatico.ca/joesabourin/airpump.jpg" alt=" - " />
<small>[ March 09, 2003, 07:36 PM: Message edited by: J&JsTA ]</small>
Re: Turning off AIR
I would just unplug it and remove it and save about 10 lbs. But, and I think I answered your same ? at "the other site" just set the coolant temp amount to something really low, something it will never ever see. Like -30 or even lower. The box is the temp in which it turns off, if it's always above this, it will never be on. <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" />
<small>[ March 11, 2003, 02:33 PM: Message edited by: TheDogofWar ]</small>
Re: Turning off AIR
It is currently set at -10.2
i think i need to set it higher to like 150 or something <img border="0" title="" alt="[Confused]" src="images/icons/confused.gif" />
Re: Turning off AIR
I would simply try one or the other.... you got a 50/50 of hittin it the first time. The way I read the parameter description in EDIT I would think that you need to bring the temp up ........ but I could be wrong <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" /> ..... I've been wrong before <img border="0" title="" alt="[Wink]" src="gr_images/icons/wink.gif" /> If it doesn't shut it off going UP....then you know what you gotta do <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
