4l60 question
4l60 question
My friend has a 98 formula auto and hes debating on what type of kit to go with if he stays with 4L60. Any suggestions on good shift kits on the market? Thanks
The "modified" Trans-Go Performance Shift kit that I use, will give you smooth part throttle shifts (which is easy on the gear train) and quick & firm shifts at WOT (this will keep the band & clutches alive). If the shift kit is done right (matched to the rear end gear ratio, motor, torque converter, & how you drive) it can have long lasting beneficial effects.
