700R4 Swap, Speedo Parts
Hey
Dose anybody have a list of part numbers or what to use, of speedo parts I would need for 700R4 swap. 2001 Z28 M6 to 700R4
2001 Z28
Red
M6 soon 700R4 HD, Banzai Enterprises
Touque Arm, Banzai Enterprises
HD Racing Motor Bay/Firewall Brace, Banzai Enterprises
Rear Shock/Spring upper Brace, Banzai Enterprises
2 1/2 Stainless Y pipe into a 3" Merge pipe, stock cats outlet removed and
inlarged to 2 1/2
Magna Flow exhaust (LOVE IT) Front of inter. pipe was inlarged to 3", not
2 3/4
3.73 gears
Power Coated calipers and rotors (just hub part)
Power slot rotors
PFC pads
Valvoline, syn fluid
Amsoil in trans, motor, p/s
Mecca fluid in cooling system
thermostat modified to open 180 deg
Computer,
Hurst shifter with shortened chrome handle
ZO6 wheels
275/35-18 295/35-18
Suspenshion tech springs
Suspenshion tech sway bars
All poly bushings, front end, rear end
Lakewood rear lower arms
Rear lower arm relocating brackets, (look like stock) Banzai Enterprises
adj. track bar with Hiems (no noise) Banzai Enterprises
KYB shocks
26 MPG
1996 Z28, Drag Car, Super Gas, Super Comp
Black, will be repainted Off White, Orange, Yellow
383 SBC, Banzai Enterprises
Powerglide, Banzai Enterprises
8" TCI
Full Tube Chassis, Banzai Enterprises
4 Link
9" Ford
Strange Struts
Being built as I type
If anybody has numbers for speedo parts let me know
Thanks
Banzai
banzaient@bellsouth.net
2001 Z28
Red
inlarged to 2 1/2
2 3/4
3.73 gears
Power slot rotors
PFC pads
Computer,
ZO6 wheels
275/35-18 295/35-18
KYB shocks
26 MPG
8" TCI
4 Link
9" Ford
Strange Struts
Thanks
Banzai
I don't have numbers but something off a 1990 or so 1/2 ton truck would work. Thats the reluctor ring and electronic sender that fits into the case in place of the speedo sleeve. And the plug end.
