slight problem
I'm 99% sure that it is not oil dripping out of your exhaust. It is either condensation built up in your exhaust or you are running rich. Your exhaust has a coating of black exhaust crud mixing with the condensation/fuel and turning it black which comes out the end of your tail pipe.
Do you have cats?
For these cars it is normal for oil to go threw the pcv line which would be oil in the throttle body. If you want to cure this search for a catch can.
Do you have cats?
