Flow rate for 48lb. injectors?
Old 03-20-2003, 10:38 PM
408 Stepside 01's Avatar
Default Flow rate for 48lb. injectors?
Does anyone know what it is for Ls1 Edit. Thanks,
Sean
Old 03-20-2003, 10:55 PM
NoGo's Avatar
Default Re: Flow rate for 48lb. injectors?
Flow Rate = Rated Flow Rate * SQRT (Actual Press / Rated Press)
Flow Rate = 48 * SQRT (58 / 43.5)
Flow Rate = 55.4 lb/hr
Convert to gram/second
55.4 / 7.96 = 6.96 gram/sec
48 lb/hr injectors at our 58 psi fuel pressure will flow 6.96 gram/sec.
Good Luck,
Kevin
Old 03-20-2003, 10:58 PM
Thanks
Old 03-21-2003, 10:46 PM
MIGHTYMOUSE's Avatar
if these turn out like typical ford injectors then you will end up with a flowrate in the low 5's to not have to screw up your maf table.
for example, i run svo 42's at 5.51 at stock fuel pressure.
