Adj rockers and installing the opti
I need some technical advice and explination here.
i know i need to take the cap off of the opti. how do i know when its in corretly?
how do i adj the rockers my buddy did it for me last time?
i have comp cam pro mag 1.6 rockers
he said something like u have to get a feel for it.
any help is appreciated.
I found a mini female hex driver (looks like a screwdriver & has a green top, other sizes are color coded) @SEARS to fit the recessed bolts that hold the opti to the alum housing, just bring it with you to sears test a couple till you find them.
For setting the RRs,
http://shbox.com/1/4th_gen_tech1.html (general how-to's)
http://shbox.com/1/4th_gen_tech2.html#adjust_valves (valve lash settings)
I prefer Method-3 using a $8 bump starter from AutoZone. Depending on your choice brand of lifters the pre-load might vary with what they recommend. Generally, most hyd lifters are set to a 1/4 preload once you find zero-lash.
