Disable CAGS with LS1 Edit?
I know at one point I saw exactly what the settings were to disable CAGS on my M6 with Edit. Now I can't find it. I did some searching and it just said to set it to something that won't happen.
Is there a correct way to disable CAGS with Edit?
TIA
Johnny5
TIA
Johnny5
Location: Richmond, VA Where fast cars, well......are hard to come by.
Re: Disable CAGS with LS1 Edit?
Just go to the m6 cags tab and change the values in one of the tests to something that will either never cut it on or make it so it cuts on and back off in a area you don't shift at. There is a disable tps % in the bottom block. Why not make that 1%?
