Need help with codes P0137 and P0157
I've been running pretty lousy at the drag strip lately and I had a friend run an ATAP and got codes P0137 and P0157. I know that these are low voltage 02 sensors after the cats on both banks.
My question is what should I check to correct this problem? My car has only been trapping around 102-103 in the quarter mile when I think I should be doing a lot better.
Thanks
<small>[ April 12, 2003, 10:51 PM: Message edited by: RedA4Formula ]</small>
Thanks
Re: Need help with codes P0137 and P0157
Here's the write up on the low voltage codes
CIRCUIT DESCRIPTION
The PCM supplies a voltage of about 450 mV between the HO2S high and low signal circuits. The oxygen sensor varies the voltage over a range from about 1,000 mV when the exhaust is rich, down through about 10 mV when the exhaust is lean.
The PCM monitors and stores the heated oxygen sensor (HO2S) voltage information. The PCM evaluates the HO2S voltage samples in order to determine the amount of time the HO2S voltage was out of range. The PCM compares the stored H028 voltage samples taken within each sample period and determines if majority of the samples are out of the operating range.
The PCM monitors the HO2S voltage for being fixed below a predetermined voltage. If the PCM detects the voltage is below a predetermined voltage, this DTC sets.
CONDITIONS FOR RUNNING THE DTC
Criteria 1
DTCs P0101, P0102, P0103, P0112, P0113, P0117, P0118, P0121, P0122, P0123, P0125, P0200, P0335, P0336, P0351-P0358, P1258 not set.
The ignition voltage is more than 9.0 volts.
The fuel system is operating in Closed Loop.
The AIR, EGR, and the Catalyst diagnostics are not active.
The fuel trim learn is enabled.
The TP sensor angle is between 2-70 percent .
OR
Criteria 2
The Power Enrichment mode is enabled for more than 1.0 second.
CONDITIONS FOR SETTING THE DTC
Criteria 1
The HO2S signal voltage remains below 80 mV.
The Criteria 1 conditions are present for 80 seconds.
OR
Criteria 2
The HO2S signal voltage remains below 420 mV.
The Criteria 2 conditions are present for 10 seconds during the Power Enrichment mode.
ACTION TAKEN WHEN THE DTC SETS
The PCM illuminates the Malfunction Indicator Lamp (MIL) on the second consecutive ignition cycle that the diagnostic runs and tails.
The PCM records the operating conditions at the time the diagnostic fails. The first time the diagnostic fails, the PCM stores this information in the Failure Records. If the diagnostic reports a failure on the second consecutive ignition cycle, the PCM records the operating conditions at the time of the failure. The PCM writes the conditions to the Freeze Frame and updates the Failure Records.
CONDITIONS FOR CLEARING THE MIL/DTC
The PCM turns the Malfunction Indicator Lamp (MIL) OFF after 3 consecutive ignition cycles that the diagnostic runs and does not fail.
A last test failed (current DTC) clears when the diagnostic runs and does not fail.
A History DTC clears after 40 consecutive warm-up cycles, if this or any other emission related diagnostic does not report any failures.
Use a scan tool in order to clear the MIL/DTC.
DIAGNOSTIC AIDS
IMPORTANT:
Remove any debris from the PCM connector surfaces before servicing the PCM. Inspect the PCM connector gaskets when diagnosing/replacing the PCM. Ensure that the gaskets are installed correctly. The gaskets prevent contaminant intrusion into the PCM.
For any test that requires probing the PCM or component harness connectors, use the J 35616-A connector test adapter kit. Using this kit prevents any damage to the harness connector terminals. Refer to Using Connector Test Adapters in Diagrams.
The PCM sets this DTC when the vehicle runs out of fuel.
Heated Oxygen Sensor (HO2S) wire: Sensor pigtail may be in contact with the exhaust manifold or the exhaust system.
An oxygen supply inside the HO2S is necessary for proper operation. The HO2S wires provides the supply of oxygen. Inspect the HO2S wires and connections for breaks or contamination. Refer to Heated Oxygen Sensor (HO2S) Wiring Repairs in Diagrams.
Inspect for an intermittent ground in the signal wire between the connector and the sensor.
Lean injector(s): Perform the Injector Balance Test. Refer to Fuel Injector Balance Test with Tech 2 or Fuel Injector Balance Test with Special Tool. See: System Diagnostic Tables\Fuel Injector Balance Test With Tech 2 See: System Diagnostic Tables\Fuel Injector Balance Test With Special Tool
Fuel contamination: Water near the in-tank fuel pump inlet can be delivered to the injectors. Refer to Alcohol/Contaminants-In-Fuel Diagnosis. The water causes a lean exhaust and can set a DTC. See: Fuel Delivery and Air Induction\Fuel\Testing and Inspection
Fuel pressure: System will be lean if fuel pressure is low. Refer to Fuel System Diagnosis. See: System Diagnostic Tables\Fuel System Diagnosis
Exhaust leaks: An exhaust leak near the HO2S can cause a lean condition. Refer to Exhaust Leakage in Engine Exhaust.
Vacuum or crankcase leaks can cause a lean condition.
If the above are OK, the HO2S may be at fault.
For an intermittent condition, refer to Symptoms. See: Symptoms
TEST DESCRIPTION
Steps 1 - 7
Steps 8 - 9
The numbers below refer to the step numbers on the diagnostic table.
If the HO2S voltage is fixed well below 200 mV , this indicates a short to battery ground or chassis ground. If the voltage is fixed near or above 200 mV, this indicates a short to a PCM ground. When the HO2S voltage is fixed near 200 mV , indicates the DTC set when the fuel system was in a Power Enrichment mode of operation. This DTC sets if the HO2S voltage is less than 420 mV during a Power Enrichment mode of operation. The engine must be at the normal operating temperature before performing this test.
Using the Freeze Frame and/or Failure Records data may aid in locating an intermittent condition. If you can not duplicate the DTC, the information included in the Freeze Frame and/or Failure Records data can help determine how many miles since the DTC set. The Fail Counter and Pass Counter can also be used to determine how many ignition cycles the diagnostic reported a pass and/or a fail. Operate the vehicle within the same freeze frame conditions (RPM, load, vehicle speed, temperature etc.) that the PCM recorded. This isolates when the DTC failed.
Lower the exhaust system to gain sufficient access to the HO2S and/or the HO2S connector if necessary. Disconnecting the HO2S should cause the HO2S voltage to display a bias voltage. A voltage staying near 0.0 volts indicates the low circuit is open, or the high circuit is open or grounded.
Disconnecting the PCM allows using a DMM in order in order to test continuity of the circuits. This aids in locating an open or shorted circuit.
CIRCUIT DESCRIPTION
Criteria 1
OR
Criteria 2
Criteria 1
OR
Criteria 2
DIAGNOSTIC AIDS
IMPORTANT:
TEST DESCRIPTION
Steps 1 - 7
Steps 8 - 9
Has anyone solved the problem with a particular fix??
I got the 57 code tonight.....I suspect it may be a temperature issue with the CATs. Reason, outside temp 52, 70mph 6th gear cruise. When I had the stock CATs in place (MAC Headers) I always had a P0420 Low Efficiency Error.....6 days ago I had a set of Ramdom Techs welded on. No codes until today. Previous temps were about the same, I ran the car a little more "spirited" on all previous trips, my family was along tonight! <img border="0" alt="[angel]" title="" src="graemlins/gr_angel.gif" />
I notice in the above that a lean condition is mentioned, I can eliminate that as well, LTrims were -03.
Maybe I'm off track, that's why I came here looking for some help and stumbled on this post.
Thanks for any suggestions <img border="0" title="" alt="[Big Grin]" src="gr_grin.gif" />
<small>[ April 13, 2003, 09:20 PM: Message edited by: Rob Orlando ]</small>
I had these same codes. They showed up on saturday out of the blue. I sprayed down the MAF with electronics cleaner let it dry completely and reinstalled it and just like that my SES light was cleared.
