LT1 dyno #'s still need some more tuning
Old 03-06-2006, 09:32 AM
roughneck427's Avatar
Default LT1 dyno #'s still need some more tuning
Well i threw down 350 rwhp and 334 rwtq with 800 miles on the engine my A/F ratio was 12.2 from 4900rpm and up and it was pulling 5-7 degreess of timing out throughout the powerband.I got an update tune to lean it out and get rid of the timing retard im hoping ill hit 370 rwhp what do you guys think with the retard and the rich mixture im taking it back at the end of this week????
BTW you guys see the mods in my sig this car is CA smog legal as far as passing a visual and passing the sniffer
Old 03-06-2006, 09:05 PM
10secondZ's Avatar
considering your air/fuel, KR, exhaust set up, and small cam those are great numbers!! get some more tuning and there will be some more in it.
Carter
Old 03-06-2006, 10:19 PM
AINT SKEERED's Avatar
I have the same exh and trust me when I say that as good as it sounds, put a cutout on it and watch those numbers go way up. I loose 24 hp over the cutout.
Old 03-07-2006, 01:46 AM
TransAm6383's Avatar
you lose it over the cutout?? you mean using it or not using it..what exhaust are you using?
Old 03-07-2006, 08:09 AM
Really?? that cat back is that restrictive you are right i love the way it sounds
guess ill have to put me an e-cutout then thanks for the info
