Procharger, AIR injection pump Question
Old 03-09-2006, 07:45 PM
BenztechHbl's Avatar
Default Procharger, AIR injection pump Question
I am going to install my procharger this weekend and realized that the new plenum has no adapter for the AIR pump. If I completly remove the pump will it set a Check Engine Light???
Old 03-09-2006, 08:58 PM
LS1Tech Sponsor
Slowhawk's Avatar
You can put a little filter on the line that use to go to the air box. Most people ditch the AIR system when doing a Procharger so there is more room for the air filter. A tuner can delete the AIR system codes so the car passes emmissions.
