Rear End hopp
i had the same problem, the whole car feels like its going to fall apart. i put lower control arms, panhard, and subframes on and the wheel hop was eliminated. on the whole set up i think the lca's had the biggest effect on that problem.
Thanks Ill look into that, however hasnt been an issue untill recently and the only upgrade is MSD Cap and Rotor and wires. So unless something is getting worn out or the New cap and rotor (the only one was shot) made a huge differance
if stock LCAs the bushings might be worn out. Check the TA mount at the trans and on the Rear to make sure it is still all tight.
Reducing flex in the suspension will help alot no matter what the car is used for.
