Bolts for convertor
Bolts for convertor
I am going to be install a Vig 3200 stall next week. I had thought I had read somewhere before that you had to buy shorter bolts because the stock ones are too long? Is this correct? If so what size and length do I need to pick up?
Me too, they are 10mm long. If you have to shim the converter, you will also need longer bolts. Check to see how much you have to shim the converter during the install and if you have to shim it, add that much to the 10mm length. You can grind down the length of the stockers if you shim it to make the bolts the right length.
