another what will it run
I'm going to go find out just wondering what you guys might estimate
95 lt1 355ci A4
hotcam, 1.6rr, stock heads
electic water pump, underdrive pulleys, 52mm tb, slp cai
pacesetter longtubes with true duals
315's street tires on the back
3.73 gears, lca, jegster torque arm (bolted in the hump), drag springs
EGR, AIR, ABS, traction control - delete
alum driveshaft
bout 250lbs weight reductions
95 lt1 355ci A4
alum driveshaft
