New GS stripes, Z28 overlays and bowties
I got my $72 dollar order from Brent Franker yesterday. Got them put on today. As usual his stuff is high quality and easy to install.
Silver reflective Z28 Overlays, CAMARO inserts and GS stripes on both sides. Red reflective front and back bowties.
Did you have any trouble on the install, with the z28 overlays? According to his instructions, you shouldn't use the water trick with the reflective colors. How did you do them? They look good.
I used the soapy water trick to install everything, it worked awesome. The best advice on installing the Z28 decals, is get a razor blade and cut them out (like in his instructions) but get as CLOSE as you can. It makes it SO much easier to line up. Make sure to do like he says and "push" out the water from underneath, otherwise it will bubble. You can use the razor blade to help seperate the application tape from the vinyl as well.
The Z28 decals were the hardest part, and I still finished everything within an hour.
Thanks for the compliments guys, it's hard to find anything that goes with dark metallic green haha! Next up, cowl hood, SS spoiler, and some wheels When I get some money lol (2 years from now..).
