Obd2
Old 03-19-2006, 05:32 PM
emj2006's Avatar
Smile Obd2
I got my car scanned with OBDII and got these codes:
PO403 - Exhaust Gas Recirculation Circuit Malfunction
PO412 - Secondary Air Injection System Switching Valve A Circuit Malfunction
PO443 - Evaporative Emission Control System Purge Control Valve Circuit Malfunction
These codes all have to do with circuit malfunction. Any tips on how to correct this problem? I cant find a website that showed the OBDII codes and their ways to fix them. Do any of you guys know?
Old 03-19-2006, 05:56 PM
DrivenWS6's Avatar
I got a couple of codes like that once and they all had to do with my AIR pump not working. Mine just ended being a blown fuse. So check all of your fuses and then I heard that them black check valves in the air lines can go bad. So i guess just check that stuff out first.
Old 03-19-2006, 11:04 PM
emj2006's Avatar
Is the AIR pump the smog pump?
Old 03-19-2006, 11:21 PM
DrivenWS6's Avatar
Yeah its the electrical pump down inside the front bumper in front of the left wheel.
