HELP needed a.s.A.P
Old 03-25-2006, 10:47 PM
DanX9mm's Avatar
Default HELP needed a.s.A.P
I need to know how far the crank hub needs to go on with a a double roller chain with no reluctor ring? (97 lt1) Since my hub is not keyed it only go's up to the key is this far enough?
Thanks for the help!
Old 03-25-2006, 10:53 PM
MattZ28's Avatar
You'll feel when it's supposed to stop moving. When the crank pulley is installed, there should be about 1/4" between the pulley and the opti.
Old 03-25-2006, 10:56 PM
DanX9mm's Avatar
I need to know how far the balancer hub is suposed to go on, but thanks for the response
Old 03-26-2006, 02:34 AM
-PEPE-'s Avatar
Reluctor Ring is the Crank Position Sensor (CPS) 96-97 only right? Dude read this, did a little search for you http://forums.corvetteforum.com/prin....php?t=1127999. 96GS#007 (username) summed it up, about the 5th or so post down in the thread, that would suck having to get another crank hub. Bottom line is you CANNOT leave any space, you have to tighten it all the way up. But if you removed the CPS gear and the crank hub can go no further you'll probably have to get a bronze gear either made or if it's on the market to make up for the 1/8" or so. Wish I could help you more.
EDIT: dude read down even further "RICHS" comments in detail about the woodrif keyways and tolerances. Good luck bro.
Old 03-26-2006, 09:11 AM
DanX9mm's Avatar
thanks bret!
Old 03-26-2006, 10:39 AM
TwoFast4Lv's Avatar
I was thinking about that key the whole time
When the hub is on all the way there should be almost NO clearance from the inside lip of the hub to the front of the crank as well as the timing chain gear and Reluctor being pinned and not moving.
Quick Reply: HELP needed a.s.A.P
