Tranny cooler
Tranny cooler
Okay i have been thinking about bypassing the radiator.. Seems like with a aftermarket cooler that bypassing would be better, cooler and pick less crap up along the way? Am i thinking to much?
I've got mine running bypassing the radiator. I'm seeing a high of 200* during the summer in stop and go rush hour traffic with a TCS4200, deep pan, and Hayden cooler.
for max cooling you will want it to go throught the radiator then to the cooler unless you buy a superhuge cooler with a fan, then you could bypass the stock cooler. In a stock system trans fluid runs hotter then the water in the radiator, think about it it has to be hotter then the water in the radiator, how else would the stock cooler cool off the trans fluid. In a sense the radiator will heat up the trans fluid(if your isnt moving/idling) but once you start moving you will be past the water temp and the radiator will then cool the trans fluid. So to get the best cooling with out having to but a Huge trans cooler with a fan, simply run the cooler after the stock cooler. I havent seen my trans go past 165. In the winter sometimes i see it struggle to get up to 125.
Originally Posted by LiquidFire350
time for the stupid question, but the trans inlet to the radiator is the top one, correct
