Adequate bottle pressure?
Racer
What should be my goal for bottle pressure? I have a NX bottle heater on my TNT F1 kit. Usually it hits about 1250psi. The heater seems to stop when it hits this temp. Is this a saftey feature or what? Is it suppose to stop after a certain temp. is reached? Thanks
Your instructions on your system will tell you what TNT uses for system pressure. The pressure switch should be adjustable, and have a set screw that controls the temperature. Yes it is a safety feature.
I lit off and adjusted my bottle heater yesterday, on the pressure sensor I have (DynoTune) clockwise increases the pressure, counter clockwise decreases the pressure. I set mine to 1050, my DynoTune Dry kit is rated for 950 PSI.
