Tools & Fabrication Hand | Power | Hydraulic | Pneumatic | Welding | Painting
Motor Lift Plates to use with cherry picker?
Old 03-27-2006, 06:42 AM
Aceshigh's Avatar
Default Motor Lift Plates ??? - cherry picker.
Where can I score some lift plates for an LS1 so that I can lift it up and yank an oil pan?? FYI this engine is on a crate, not in a car with a trans hooked up to it.
I'm trying to do this for a member who needs my GTO pan asap.
I thought I could lift it with chains but the chains obviously will go under the oil pan and that won't work.
Anyone know where I can get these, I need them ASAP. Thanks.
Old 03-27-2006, 08:33 PM
2K2WS6TA's Avatar
Can't you just run a bolt in the front and rear of the heads and lift it that way, instead of looking for lift plates
Old 03-29-2006, 02:41 PM
BLKWS6's Avatar
exactly what he said.... just did this last night to put a motor in a crate. works just fine.
Old 03-29-2006, 03:00 PM
Camaroholic's Avatar
Never seen 'em for an LS1.
I have the Happy Hooker for my LT1 though. Hey, looks like on the web site, they say it works for the LS1. Those things are great.
Here's some pics in action on my motor...
http://www.akmcables.com/l99.htm
Old 03-29-2006, 03:02 PM
Brains's Avatar
I've always just used bolts and a chunk of chain myself...
Old 03-29-2006, 04:56 PM
69chevy's Avatar
The chain works a lot better since you don't have to go look around for the lift plate but I have a lift plate and have to admit that I like it alot better than the chain since I don't have to find places to bolt the chain to and everything. Just my two cents.
Oh, forgot to mention that the lift plate I have is for a carb'd motor. Not sure if it applies to this situation but just go ahead and use the chain .
Quick Reply: Motor Lift Plates to use with cherry picker?
