Will it hold together?
Old 03-27-2006, 10:33 PM
IVRedZ28LS1's Avatar
Default Will it hold together?
Just installed 4.10 in the stock rearend. Has anyone slap on a set of MT ET street Drag Radials on the Stock Rearend with 4.10. And Idle launch it a couple of times at the track. Will it hold or will it blow apart? Let me know if anyone has done this before. I plan to get a 12 bolt with 4.10 and True trac later. Just wondering if it will hold a couple of runs down the track with the MT drag radials.
Old 03-27-2006, 10:39 PM
RoastEmSS's Avatar
it all depends on how u install them and the breakin period, i know stangkilr has made at least 20 passes on his with radials and he runs 11.6s on stock 10 bolt
Old 03-27-2006, 10:57 PM
keliente's Avatar
I had a crapload of passes on mine with a BFG drag radial...when I went to an mt dr I was on a flatbed for the way home.
Old 03-27-2006, 11:21 PM
Racer
UL LOSE's Avatar
Ive had NO problems. I have 4.10s,Vigilante 3000,Exhaust, And spraying 150hp shot off the line! I have 275/40/17 MT E.T. Streets(20psi!). Bone stock suspension and driveline. No susp. bolt ons or anything! Pulling 1.53 60'! Ive launched it a good 10-12 times on the spray. Runs 1.5s all day! Turns 11.2s@119!
Old 03-29-2006, 09:00 PM
Thanks for Replying Guys.
Old 03-29-2006, 10:32 PM
markp03's Avatar
do you have a auto? i run 11.7's with 3.73s in my stock 10 bolt but i have a auto.... if you a m6 you will probly rip them apart especially if you are running clsoe to 400+ hp and tq
