grinding with my t-5
Old 03-28-2006, 03:45 PM
allaboutfun's Avatar
Default grinding with my t-5
Ok guys i recently pulled my v-6 out of my 94' firebird and changed it to a 93'
LT1. So for the trans i bought a rebuilt t-5 out of an 89' camero and i just went and bought a stock clutch and flywheel for the coresponding year. when i drive the car my second and sometimes third gear grind and always reverse. So i bled the system and saw no change. I then built a custom pushrod out of a bolt i ground smooth. That temporarily fixed the problem until the slave broke with pressure. I bought a new one pre bled and still have the problem. The v-6 slave and rod are the same as the 88-92 v-8 t-5 setup. Any idea's...
