Question about 10-Bolt.....
So I recently broke my 10-bolt....
now my question is, I was given a 4-channel rear for free and I want to put it in, I know because I dont have TCS I WILL lose ABS
BUT....
what if I were to take his wiring harness off of his TCS equipped car and install it (same plug on the body) and see if the ABS works then. Of course I won't have the TCS, but hopefully the ABS will work right ?!?
so would I have ABS ?
BUT....
You most like still wont' have ABS. but try it anyways.
If it doesn't work, just swap the internals from the TCS rear to your rear, but don't forget to slap the reluctor ring that is on your diff to the good one from the TCS rear.,
