Msd Digital Window Switch Wiring
I was wondering If any of you have the MSD digital window switch and how you wired it for nitrous. I have been having some problems lately with it and was wondering how you have it wired to the solonoids. I had it wired with the grey wire but the parameters were backwards (it would kick on when it was supposed to kick off). Thanks any help would be appreciated
MSD window switch wires:
Gray - not used
Yellow - White wire on the relay
White - Tach lead
Red - Switched hot
Black - Ground
Relay wires:
White - yellow on the window switch
Red - WOT switch
Black - 12V hot
Green - solenoids
Hope this helps.
Eric
Gray - not used
White - Tach lead
Red - Switched hot
Black - Ground
Relay wires:
Red - WOT switch
Black - 12V hot
Green - solenoids
Hope this helps.
Eric
