Spark plug question
Spark plug question
I have a 98 Z28M6 that has 106000 miles on it. I want to know if I should replace the spark plugs, And if so what brand should I use when I do change them. Should I go with ones from the dealer if I am running a set up with basic bolt-ons. what wires should I use and what brand should I use when I do change them. Any onfo helps. thanks.
There have been many posts about this, but anyway. You'll find most people are using NGK plugs, for your setup ( basic bolt ons ) the TR55s should work good. I personally use MSD plug wires or you could go with the Taylor wires. Hope this helps, If you search you'll find several posts on these subjects.
