Help!! M6 Swap Questions
Old 04-10-2006, 12:14 AM
BigJoeBob1's Avatar
Default Help!! M6 Swap Questions
I am swapping a 6-speed into my 2000 Trans Am. I would like to know how everyone rewired their A4 harness. CAGS, VSS, Reverse Lockout, Cruise Control, Hatch Release, Clutch switch and whatever else can be complicated. Also, what are the other complications some of you have ran into when swapping and what did you do to fix it. I need the wiring setups for all of these so hopefully it will all go smoothly. Thanks
Old 04-10-2006, 12:54 AM
93TAWicked1's Avatar
Look at the sticky at the top everything you need is there, gotta look a little bit though
Old 04-10-2006, 10:43 AM
camaroguy26's Avatar
what made you decide to do the swap? I'm wanting to do it too but I'm indecisive about it. I have a kit lined up already but not sure if I should buy it or not
Old 04-10-2006, 11:31 AM
gettinthere's Avatar
It sounds like you are going to re-use your A4 harness, but actually getting an M6 harness is the easiest thing to do. Then it's just plug and play.
Old 04-10-2006, 09:01 PM
Farmer2's Avatar
https://ls1tech.com/forums/manual-transmission/436809-a4-m6-swap-peeps-get-here.html
Old 04-11-2006, 02:10 PM
Bad Blu Formula's Avatar
I just did the swap a few weeks ago and just followed all the pictures and instructions from the sticky above.
Old 04-11-2006, 05:39 PM
8a8mfh's Avatar
I'm getting ready to do the swap, just waiting on the clutch.
With HPTuners I'm going to disable CAGS and other codes that might pop up without the reverse lockout circuit complete.
The neutral safety and backup lights are basic.
Be sure to check the sticky threads in both transmission forums because they are different.
