oil change indicator
oil change
i got my first oil change on my z28 the other day and every since the change oil light has been coming on..it only comes on when i start it up and stays on for like 1 minute then goes off and doesnt come back on until i restart it again???any ideas anyone ever had their car to do this...is it normal
also whenever i put significant amout of weight in my hatch or in the backseat my car has a bad grind/rattle to it...i figure has to be something with my suspension...only does it when i have probably 200lbs or so in the back????
'Bird Director
The oil change light is your car's "friendly" reminder to change your oil. The computer bases it off of how many hours/miles the car has gone (I believe) and decides on it's own when it "thinks" you should change your oil.
To make it go away, do the following:
Turn the key to the "on" position (vehicle not running).
Press the accelerator to the floor three times (no more than 5 seconds apart).
The next time you turn the car on, the little light won't come back on again (until it "thinks" you need another oil change).
