New NOS Drive-By-Wire/Wide open throttle window switch
Old 04-10-2006, 12:44 PM
LS1TECH Sponsor
Jay M's Avatar
Default New NOS Drive-By-Wire/Wide open throttle window switch
NOS has just released their new DBW/WOT window switch. Here is the press release on it.
Tired of trying to figure out how to install a WOT switch by your gas pedal on your Drive-By-Wire vehicle? Well, NOS has the answer. NOS is proud to introduce their new Drive-By-Wire WOT/window switch. Designed to work on sequential firing, multi-point fuel injection systems, the NOS Drive-By-Wire WOT/window switch allows for trouble free easy nitrous activation. The NOS Drive-By-Wire WOT/ window switch features adjustable low and high RPM set points and TPS activation all in a compact easy to install design.
The NOS Drive-By-Wire WOT/ window switch does not work on “falling” TPS signals (ex. Low throttle is 5 volts, high throttle is approximately 1 volt, such as the 2005 and up LS2 GM engine)
The NOS Drive-By-Wire WOT/window switch comes complete with full instructions and T-Tap connectors for a quick, easy installation.
This is available now, but is unfortunatly not on the web site yet.
Thx,
Jay M
Old 04-10-2006, 12:51 PM
GFORCE1320's Avatar
So it won't work with my 05 GTO throttle body ?
Old 04-10-2006, 12:55 PM
LS1TECH Sponsor
Jay M's Avatar
We are working with it so it will work on the falling TPS signal but we do not have it ready as of yet. The LS2 has a falling and a rising TPS signal but you cannot read off of the rising signal due to it not being a linear voltage. It could give you false activations.
Old 05-24-2006, 09:45 AM
Jtizzle's Avatar
just got mine in a few days ago. Working on figuring out the wiring on my C5 now. Does any one have a place to get ECU pinouts?
Old 05-24-2006, 10:15 AM
860 Performance's Avatar
picture?
Old 05-24-2006, 10:08 PM
Robert56's Avatar
Here ya go. www.teamzr1.com/pcmecm/99pinpcm.html
Robert
Old 05-25-2006, 03:29 PM
Jtizzle's Avatar
Awesome! thanks alot! now i can wire this bad boy up tonight and maybe spray one of these days.
Quick Reply: New NOS Drive-By-Wire/Wide open throttle window switch
