wot switch question
You will still run the wot switch. The window switch is juts desighned to keep the nitrous from comming on before a set RPM and shutting off at a set RPM if over reved. The wot switch is what actually tells the car you are at wide open throttle and its safe to spray.
Dave
Dave
thanks for the speedy reply, also, where would the ( on the Msd digital window switch) the yellow ( normaly open) wire go, and the Grey ( normaly Closed wire Go. im using two N20 noids in a row, and one fuel noid, i hear its safer that way, incase one of the N20 noids goes static the other one will still close... i guess
Robert
