Wiring diagram anyone??
8 second mod
Im got the N2O kit yesterday, just waiting on the wot/window switch, and the switch pannal.
anyone have a wiring diagram for a system with
Arm, bottle opener(noid style), heater, and a electric NX tps wot/window switch?
anyone? thanks.
once all the parts come in, the kit will be going in the vett!!!
hoping to have all the stuff so i can mess with it on saturday. should be able to get it all done in a day.
anyone? thanks.
Unfortunately, wiring diagrams are extremely specific to certain your setup. I would plan where you want to run the wires. then I would find a place to ground wires in your car that is along your wiring route. Plan where you want to put the solenoids and bottle bracket. If you don't have different colored wire, i would go buy some. Run your signal on one color, your ground on another, etc...After you get all your hardware, you should map it out on the car and you can construct your own diagram fairly easily from that. Power ground signal. YOU CAN DO IT!
Noyzee, sounds like your going to be busy for a while with all the wiring, lol. I would suggest getting in touch with NXRicky. He can get you a complete diagram specifically for your setup done pretty quickly, if you can talk him into it, lol.
8 second mod
i'll figure it out, not a big deal, i just thought if some one had it, it would save me a little time you know.
thanks for the imput. im going to head out now and start mounting the bottle ect.
