Noise after new clutch and flywheel install?
I just finished putting in a spec stage 2 clutch and fiadanza flywheel. I'm getting a noise that is very low, I can feel it in the clutch pedal more then anything. It only does it when starting off a light or on down shifts. I was told that it is do to clutch not being broke in. Other then that the car runs and shifts great. Just wanted to see everyone thinks it is. Thanks
Restricted User
No, I think I have the same problem. I installed mine about a year ago now and just recently I have noticed that if I drive the car and then after it has set for about 30 minutes to an hour I can take off and while letting the cluth out it makes a noise and you can feel it in the pedal. I believe that it has something to do with the slave but I am not sure and need others thoughts.
