Howling noise
Howling noise
I've got a howling noise from the engine compartment that I only really notice during low speed turns. (1st and 2nd gear) It sounds like a eaton blower (which sucks because it's not) but I suspect it's my power steering pump. In order to see if this is the problem, can I run the car without the serpentine for a short while?
If I pull the belt off I'll lose power steering and the alternator charge, is that everything?
If it is the PS pump, should I get a new stocker or look at a possible aftermarket pump? I doubt it would be worth getting this one rebuilt.
You will also loose the water pump with the belt off. Do you still have A/C in the car. Might want to check that as well, Mine started squeeling on me before I removed it. As far as running it with out the belt it should be fine might want to do it after it's completely cooled down.
