6.0 gasket question
6.0 gasket question
Since I will be using a 6.0 head, I must order a head gasket for the 6.0 head, right? Is there a difference between years? What truck should I say that the heads came out of? Whats the thickest gasket that I can use without affecting the quench too much? I want it to lower the compression as much as possible without affecting the quench. And..should I go with cometics?
thanks
thanks
if you go with the stock GMs (for 6.0l mls) they only come in one thickness. i think the mls ones are 2002+
cometics you can get in different thicknesses. .054-.125
the GMs are cheaper and just as good, if not better, but if you want different thicknesses to lower the CR youll have to go with the cometics,
i got .067" which is as thick as i would go, but thats just for my setup.
