General Maintenance & Repairs - what should i do... 53k 8 yrs old...
1baddls1
04-18-2006, 09:28 PM
99 z28 A4
ive done plugs and wires
im thinking i should change i rear end fluid, drop the pan and change the tranny fluid and filter
other reccomendations????
thanks guys
98blackvert
04-19-2006, 12:05 AM
i have a 1998 trans am with 49k and i flushed and changed all fluids new filters, spark plugs and wires and new suspension bushings all around
1baddls1
04-19-2006, 07:59 PM
suspension bushings all around??? rot is not our friend... how much does that run???
NHRAMAN
04-19-2006, 08:03 PM
GEE...you haven't changed fluids in 8 years!! you gotta be kidding--even with low miles,thats not cool. You probably have GUNGE in there... :jest:
78LT383
04-20-2006, 07:44 AM
What are your goals? Are you just looking for maintenance suggestions, or are you looking for performance modifications to meet a specific performance objective?
1baddls1
04-20-2006, 11:46 AM
well i just picked up the car 2 months ago, so it hasnt been up to me till now, im planning on flushing all the systems, i was just curious as to anyting else i should do
perf wise im going for full bolt ons
JakeY2KZ
04-20-2006, 11:50 AM
Replace your fuel filter as well while your under the rear of the car.
1baddls1
04-20-2006, 06:02 PM
check!!! already got one.... just gotta install
NHRAMAN
04-20-2006, 06:04 PM
:jest: Thought you meant you just thought of maintenance now.....like said above, Fuel filter also for sure... :judge:
camaroguy26
04-20-2006, 06:17 PM
Just go with a set of poly bushings instead of replacing stock with stock. They're only about 170 bucks for the set at BMR I believe. Most people usually forget the brake fluid too, it's a good idea to flush the brake lines out with new stuff. And it's probably a good idea to change the belts, timing belt should be changed at 60,000 according to the books but you might as well change it now. PCV valve too wouldn't be a bad idea, they don't usually go out that I know of but it's only a few bucks. One spot that's usually not even thought about is the driveshaft u-joints, just get a kit to rebuild them with new bearings and whatnot. it's not expensive if I remember.
slayer_taunu
04-22-2006, 02:44 AM
dont forget the air filter! if its a stock type paper filter and its dirty, replace it with a K&N or equivalent. if it's a K&N type cleanable filter, might be a good idea to clean and re-oil it. the kit to do that is like $10 from autozone
LS1FIRE
04-22-2006, 04:39 AM
Coolant change
