make sense to you?
make sense to you?
here are our results, mind you our best run at a track with these results is 12.30 at 115 with full suspension mods, m/t et streets, the tc is 4000 stall on an '00 hawk, think the tune is wrong with those knd of numbers? 60' to the best of my recelection was 1.62, something seems wrong here
see here is the problem, with what we got, we should be making way more, cam listed and heads listed are correct, electric water pump, LS-X 90/90, 36# injectors, 3.73 gears, moser 12 bolt, rossler built 4l60e, smooth bellow, new fuel pump, with approx 3700lb race weight
