Drag Racing Tech
How Hard is a DSL install?
Old 04-20-2006, 08:32 PM
hashtagBMW
Speed Density's Avatar
Default How Hard is a DSL install?
Well I just found out I have to run a Drive Shaft saftey loop now since ive got ET Drags. Were is the cheapest place to buy a DSL and how hard, how much time do they take to install?
Old 04-20-2006, 08:38 PM
theblur98ss's Avatar
If you buy the lakewood it's very simple to install. I think they're around $50 from jegs but it bolts right in place of the brace under the car.
Old 04-20-2006, 08:40 PM
hashtagBMW
A buddie of mine was saying you had to mess with the interior to hook it up, true? I cant see why they would make the bolts that big.
Old 04-20-2006, 09:29 PM
SPEEDYws6's Avatar
Not the lakewood, which is the only one I can tell you about, cause it's the only one I have used.
Old 04-20-2006, 09:44 PM
blueovalbeater's Avatar
Jegs or summit brand for our car runs about 50$ and takes about 45 minutes to install(just bolts in place of g-load brace. Now im not sure but if you have a chassis mount torque arm you might have to buy a new torque arm with a built in drice shaft loop. later. and by the way dont try wrestling it in just take the driveshaft off for install.
Old 04-20-2006, 10:53 PM
hashtagBMW
Im getting the SUM-G7900.
