strange and rough idle after header install
Old 04-24-2006, 03:42 PM
baird95z's Avatar
Default strange and rough idle after header install
well i installed the headers about a week ago and after i got my o2's in it decides to run like crap and gave a really rough idle and run rough till about 1700 rpm. i checked all the wires and turs out 2 were burnt, so i changed the two and put plug wire wrap around them. now its still rough and no better then before. any advice?
~baird
Old 04-24-2006, 06:00 PM
steez's Avatar
check the o2's and the plugs when i did my as&m's it burned my #7 wire i was runing on 7 cylinders
Old 04-24-2006, 10:01 PM
baird95z's Avatar
i just replaced the wire and had some trouble getting it on. ill check it again and will check my o2's.thanks for your input.~baird
