starter problem! help pleae
Old 04-24-2006, 10:16 PM
99transamws6's Avatar
Default starter problem! help pleae
Hi my car is not starting. nothing is happening. no cranking, no clicking noise, nothing. does anyone have an idea of what it is? my guess either the starte or the ignition but what test can i run before i go and buy a new starter? please thanks for the help guys.
Old 04-24-2006, 11:35 PM
angel71rs's Avatar
Need more info, did it suddenly start happening, any work done before problem surfaced? Is your other stuff coming on, lights radio, etc? Always start by checking your battery connections, must be clean & tight. Auto or M6? A4s have a neutral safety swtich than can go bad, M6s have a switch on clutch pedal. Check their connections 1st.
Old 04-24-2006, 11:39 PM
calongo_SS's Avatar
Try charging the battery, try a jump start.
Old 04-25-2006, 12:49 PM
all the accesories work and turn on. no recent mods. its a manual 6-speed. it just happened out of nowhere
Old 04-25-2006, 12:51 PM
ls7_ws6's Avatar
Make sure nothing has happened to the ground wire on your starter. Make sure you ENGINE is making good ground.
Old 04-25-2006, 01:35 PM
GuitsBoy's Avatar
Happened to me last year. Starter solenoid. Swap out the starter. Valvegod sells them for pretty cheap.
For the time being, see if you can tap the back of the starter with a hammer to get it to kick over. Carry that hammer around with you so you dont get stuck.
